hi guys I keep hearing this weird sound coming from my pc. have you guys heard this before? really hope someone can help me on this as it's annoying me. ignore the laughter at the back.
CPU RYZEN 2600X
MOTHERBOARD GIGABYTE X470 GAMING 7 WIFI
PSU SEASONIC 850W GOLD
RAM CORSAIR 3000MHZ CL15
GPU GIGABYTE 1070TI GAMING
SSD CRUCIAL 250GB
HDD 2TB SEAGATE BARRACUDA
CPU FAN NOCTUA NH 14 AM4
https://linustechtips.com/topic/1060272-pc-weird-sound/
I can't even check the clip. But try first identifying where sound is coming from. You can use fingers to push or stop fans, HDDs and such to see what effects noise. If nothing changes, then its most likely coil whine, usually issue of GPUs and PSUs. You can't do nothing to it but adapt. Or change part causing it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1060272-pc-weird-sound/#findComment-12533729
yeah i tried unplugging my case fans cpu fans still same. so i was thinking it's either gpu or cpu. but if it's coil whine I need to bring it back rite?
https://linustechtips.com/topic/1060272-pc-weird-sound/#findComment-12534155
