Does it get to your OS before restarting again?
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417511
Check all of your PSU cables, all of you sata cables and then make sure you are booting to the correct HDD or SSD.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417513
Remove the non critical components one at a time and see which/if one of them is causing the problem. Most likely something is not connected correctly.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417514
Try booting without gpu and only 1 stick of ram. If you boot and it doesn't loop then you know it's being caused from 1 of the two.
CPU: Intel i5 3570k @4200 | Motherboard: ASUS P8Z77-V LK | RAM: 8gb Crucial Ballistix @1600 | GPU: Evga GTX 660 TI x2 SLI | Case: Corsair C70 | Storage: WD Black 1TB, Samsung 830 126GB SSD, Kingston V300 120GB SSD | PSU: Corsair HX850 | Display(s): ASUS 2ms 24inch 1920x1080 | Cooling: Corsair H100i | Keyboard: Razer BlackWidow Ultimate 13 | Mouse: Razer Naga 13
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417540
Finished build my pc, hooked it up and turned it on and after 10 seconds of everything running, it turns off . It will then turn itself on again and go through the whole process over and over... Any tips?
Did you give the all the power too all the components for example to the GPU?
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417553
It is also constantly showing me debug code 15 - Pre-Memory North Bridge initialization is started.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417613
Some asus motherboards will power on then turn off the first time you plug them in
CPU: 4770k @ 4.6 MOBO: Asus Maximus VI Formula RAM: G-Skill Trident X 16GB @ 1866 COOLER: EK Custom Loop (Supremacy/780 Block/360mm/280mm/MCP35X/Bitspower Res) GPU: Galaxy GTX 780 HOF @1425  STORAGE: 120GB/240GB Samsung 840 Evo, 2TB WD Black, 3TB Seagate Barracuda PSU: EVGA Supenova 1000G2 Case: Corsair 750D with 140mm Akasa Vipers MONITOR: Asus VG248QE
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417618
Disconnected all non necessary components and it still wont stay on.
Are you able to get into windows or into bios, are you getting any visual on your monitor? If it keeps looping on and off then unplug your psu from power outlet, make sure theres no metal touching motherboard which could cause a shorting. Make sure your motherboard is on all your standoffs in your case (might want to remove a few standoffs if they are not needed in keeping motherboard attached to your chassis). Make sure your 24pin and 8pin power cables are connected right, make sure your cpu is installed correctly and your heatsink is attached to the motherboard in place with adequate thermal paste. Make sure to boot with only one ram stick, one gpu, and one hdd during troubleshooting, once you go through all those steps then reconnect your psu and try booting up again. Let me know if your cpu and psu fan turn when booting.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417758
@IdeaStormer
My guess would be something is shorted out, time to pull the motherboard and make sure all the standoffs are correct and not odd junk is lodged under the motherboard. Make sure the screws are not so tight that there might be some contact with a power trace or something weird like that.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417770
I doubt that anything shorted out, as it seems to run fine for long enough and my case has pre-installed standoffs. I also made sure not to screw the motherboard in too tight for fear of undue stress. All fans turn on correctly, though at a faster speed. They then slow down after a while and after that it turns off. I also get no visuals on the monitor upon startup.
EDIT: I started it up this time and it stayed on. I'm going to slowly add components and see if it makes a difference.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417819
Try experimenting with different arrangements of RAM sticks. Occasionally, you'll get a dodgy one, and will need to remove it in order for the PC to post.
Check out my video work at youtube.com/SuperUserTech
Acer Aspire 5750G - i5-2410m | 8GB 1333Mhz RAM | 500GB 5400RPM HDD | Nvidia GT540m
2xBenQ EW2440L | Sennheiser HD600 | Corsair Vengeance K65 | Corsair Vengeance M65 | Panasonic Lumix G7 | Panasonic 20mm F1.7
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1417843
CPU fan shuts off also? or just casefans?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1420960
Don't worry i sorted it out, but there is one problem. My debug code says that some architectural protocols aren't available, but my computer seems to still work fine. O.o
That may be just that you have disabled some features of mobo such as integrated graphics.
https://linustechtips.com/topic/106027-first-boot-problems/#findComment-1426368
