Hi, so I know I have posted this build before, but I want to make sure if it is a good one. I was wondering if I would need case fans or not as im not sure the fans that come with the case are enough. I live in the us, rgb ok though not required. Money wise im a bit leniant.
https://linustechtips.com/topic/1060168-first-desktop-build/
3 minutes ago, DEEJAY said:
over $600 for just these parts... quite bad value...
for 1440p, you can have better gpu
get ryzen and rtx2080 with this buget
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12531807
$600 isnt much when it adds up to $2300. Ryzen will have a much harder time reaching high frame rates
Desktop benching:
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12531826
11 minutes ago, DEEJAY said:
Honestly since I know rock bottom about computer specs, this is why im asking u the community.
much better for the same price:
PCPartPicker Part List
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($369.99 @ Newegg)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($88.09 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($179.99 @ Amazon)
Memory: OLOy - 16 GB (2 x 8 GB) DDR4-3000 Memory  ($69.99 @ Newegg)
Storage: HP - EX900 500 GB M.2-2280 Solid State Drive  ($64.89 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card  ($699.99 @ Amazon)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: Rosewill - Capstone 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home Full 32/64-bit  ($119.99 @ Dell)
Monitor: MSI - Optix MAG341CQ 34.0" 3440x1440 100 Hz Monitor  ($409.99 @ Newegg)
Keyboard: Logitech - G413 Carbon Wired Gaming Keyboard  ($69.99 @ Amazon)
Speakers: Creative Labs - A250 9 W 2.1ch Speakers  ($29.00 @ Amazon)
Total: $2326.77
Generated by PCPartPicker 2019-05-02 04:34 EDT-0400
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12531844
Total: $2326.77
thanks! any ideas on case fans whether I need any?
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12531854
the 2 fans included should be enough but you can get an extra 1-2 if you want.
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12531859
A few notes to value on individual parts. I won't argue Intel vs AMD since many here are. Underlined texts are pcpartpicker hyperlinks!
CPU Cooler: The Noctua listed ins't any more powerful than the Darkrock Pro 4 and is more expensive. The colors are also hideous lol. If you wanted a plenty powerful RGB AIO to match the following case suggestion, check this out. I'll add the RGB AIO to the list below, but if you want air, do the Darkrock Pro 4.
GPU: The 2070 Windforce is pretty cool, and pretty powerful. If you're looking for a value, this Vega 64 is on a great sale, factory OCed with a high-mid range cooler, and will go toe to toe with the 2070 at 1440p. Check some youtube videos!
Case: to your question, since you're using that CPU cooler and a fan blown GPU, it wouldn't hurt to add a couple of intakes, since that case only comes with one. I personally think this case is a good buy, since it comes with 3 intakes, an exhaust, and the airflow supports either an AIO radiator (like the one listed) or extra exhaust on top if you choose. Good airflow, decent cable mgmt. (And hey! RGB!) Check out the newegg listing for it to see what that could look like with the AIO. Very sexy.
PSU: You're heavily overpaying. For a similar quality and a good savings, check out this one and this one
Peripherals: I won't touch your peripherals, since that's a more personalized experience, other than to point out that a 27" 1440p 155hz 1ms monitor can be had for significantly less. I'll add that, but that's again all up to preference. A windows key can be had for $5 nowadays on ebay, or the unpaid windows is always an option.
So for small adjustments without touching your core parts (except the GPU), we keep or gain quality, maybe gain some sex appeal (I think so... Certainly on the cooler and the case.)  and we spend significantly less.
https://linustechtips.com/topic/1060168-first-desktop-build/#findComment-12532722
