For work I usually need a dualboot, and I've always been under the impression that having the operating systems in seperate drives, rather than partitioning a bigger one, is saffer (saffer as in less likely to cause me trouble) but correct me if I'm wrong. In my current laptop I removed the disc drive and put a second SSD in its place.
However my laptop is getting old, and I'm thinking about getting a new one. Sadly, most thin laptops these days cannot fit two drives. Say if I bought one with a thunderbolt 3 port, could I get an adapter and run linux from an external nvme stick? Would it run seaminglessly? Is there a better way to do it?
https://linustechtips.com/topic/1060162-running-linux-through-thunderbolt/
Running nvme for that case is pretty pointless. You can easily run Linux off of a regular USB 2.0 HDD or even a Thumb drive. I'd recommend an USB 3 ssd tho if you are on a regular.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Well, since thunderbolt 3 passes 4xPCIe I thought it would make a difference
Obviously nvme would be quite a lot faster over sata ssd but that doesn't justify the price difference etc.
Plus I doubt you would notice any difference.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
This bad boi
https://www.amazon.com/Samsung-500GB-Internal-MZ-76E500B-AM/dp/B0781Z7Y3S
And this
https://www.amazon.com/ORICO-External-Enclosure-Support-Tool-Free/dp/B01LY97QE8
will solve your problems
