Ryzen 5 2600 and RTX 2060 Issues
Uvite
Just got a brand new RTX 2060 and Ryzen 5 2600. However I've had a few issues. Its been running GTAV at sub-30fps when videos show it playing >100fps. This needs to be fixed, either by changing something or by buying additional components or replacing faulty ones.
Userbenchmark: https://www.userbenchmark.com/UserRun/16587227
EDIT: Wrong benchmark
Did you DDS the drivers from your old video card before installing the new drivers for your 2060?
Aside from drivers, read its frequency. If it's showing 1350MHz constant, the BIOS is half broken
Desktop benching:
What settings are you runnning on? GTA can be verry damanding espcially with a lot of anti-aliasing so dial down some settings (or to the ones in the vid)
