Hi LTT,
          I'm looking to sell My Acer Predator 15 gaming laptop specs below and I don't know what price to give it.I need some tips from you guys on what price I should give it.
CPU: Core I7 7700HQ
GPU: Nvidia GTX 1070 (8GB VRAM)
RAM: 16 GB DDR4
STORAGE: 256 SSD (no HDD Because of personal files)
Comes with the Frost core fan accessory and with a 3 year international warranty
Tnx
https://linustechtips.com/topic/1059321-how-much-does-it-worth/
11 minutes ago, BarBakedQue21 said:
Hi LTT,
CPU: Core I7 7700HQ
RAM: 16 GB DDR4
Tnx
7 minutes ago, hconverse02 said:
  You'd have to check with asus directly.
Its Acer not asus
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523686
2 minutes ago, Ryujin2003 said:
Also, add an HDD. You'll get more if the other person had to do less to get it working. Otherwise, they'll already want less than you offer simply because it needs an HDD.
I  have important personal files in my harddrive and if i wipe it it will degrade the drive.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523689
No it won't.
HDD can be wiped a thousand times.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523695
12 minutes ago, hconverse02 said:
$800 ~maybe~ just because it is a laptop. Also I don't think warranties are transferable.  You'd have to check with asus directly.
800 seems awfully low for a predator with an, albeit, older i7 and a GTX 1070.
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523706
It's worth 1,200$ or so honestly. 1070 laptops aren't getting much cheaper nowadays
The Louvre
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523709
3 minutes ago, BarBakedQue21 said:
Really? cause whe i wiped my drive one time and check hardrive sentinel the life percentage of it decreased
if you do it the wrong way, yeah.
Why would you care if it degraged?
You're gonna sell it anyway.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523715
Just now, BarBakedQue21 said:
its not even that old cpu like it was 2 gens ago
The CPU is pretty outdated, I'm not gonna lie. 7 series was a long time ago, remember the mobile CPU platform releases separately from the desktop variants. But the laptop is worth 1,200$ and under.
The Louvre
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523722
yeah i want to give the buyer what he paid for.
256 gigs of SSD storage though? I wouldn't even think of paying top dollar for a laptop that's missing the HDD. Just wipe the drive.
The Louvre
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523724
He paid for a used HDD, there's no guarantee it will work fine, even if you're not wiping it.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523728
i see tnx your brother
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523730
Not for laptops, new 7th series still sold new today.
The 9th gen is pretty new.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523735
9th is very new, I thought 7th was phased out a couple years ago though? I think you might be confusing it with the 8th gen since 8th gen is still being sold on new machines.
The Louvre
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523742
2 minutes ago, WikiForce said:
Yeah, i know. Without SMART being enabled in bios, you can't check your drives health but there's no such thing for me in crystaldiskinfo. I never heard of that software that you use.
ohh sorry its was HARD DISK sentinel not drive sorry
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523778
Damn that would be overpriced for a used laptop.  $1000 would be a great sell if he can manage to, but if someone wanted a new laptop with a full warranty and a newer cpu, I doubt they would mind paying $400-$600 more when theyre already paying >$1000.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523787
Smh the cpu is nowhere near outdated no idea where you've got that idea from - You can still game on a sandy bridge I7 so, No thanks, My skylake CPU is holding up fine.
https://linustechtips.com/topic/1059321-how-much-does-it-worth/#findComment-12523860
