I need help with my RX 580 8GB
Tika
ok, thank you, i shall delete the nvidia drivers.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
Done.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
Make sure your drivers are up to date. On my 580 it would crash and stutter on older versions of drivers.
22 hours ago, Tika said:
Done.
What all have you tried? Is your GPU plugged into the top slot and have you tried double checking to make sure the GPU is seated securely and firmly.
As well as the PCIe power cables plugging into the GPU. Make sure the plug audibly clicks when plugged into the GPU. If using semi-modular PSU also check the plug going to the PSU.
What model and brand of PSU are you using?
Also not only delete Nvidia drivers but also AMD drivers. Then reinstall the latest from the website.
CPU: Ryzen 5 2600 4ghz @ 1.35v  CPU Cooler: Mugen 5 Rev b  Motherboard: MSI B450 Gaming Pro Carbon  GPU: Zotac RTX 2060 +150/+1000 Memory: 16GB Viper 4 @ 3200 CL14 Samsung B-die  Storage: 1TB Patriot VPN100 NVMe; 500GB 860evo; 128gb 840pro CaseCooler Master Q500L  PSU: CX750M V2 Operating System: Windows 10 Pro Other: 6 Corsair LL Fans; 2 aRGB Strips
