Hi my name is nate,
qyestion 1 \/
i have been wondering will my pc bottle neck if i pair my cpu with a rx590 (note: my cpu is a amd a10 7800k)
question 2 \/
Before that i have been having issues with my games as of late. I meet all requirements for the games i play but even so i still lag (note: i do not have my rx590 currently installed) so bottle necking wouldn't be the culprit here. So i was thinking maybe it would have to do something about my integrated graphics or something else.
Please help i have gone insane from this.
https://linustechtips.com/topic/1059040-help-please/
What GPU do you currently have?
Depending on the game even with your current GPU, your CPU could still be holding it back if the game is more CPU bound.
I definitely see the A10 bottlenecking the heck out of the RX590.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1059040-help-please/#findComment-12521002
Your CPU is from 2014, and it's a low end CPU from 2014. What games are we talking?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1059040-help-please/#findComment-12521007
20 minutes ago, theunwantedsorrow said:
@fasauceome ohh ok. Then what kind of gpu would you recommend me. That could play some demanding games properply like AC series or GTA V on all high that give out reasonable frame rates
At the very most, RX 570. But your CPU will keep you from playing many demanding games at high frame rates.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1059040-help-please/#findComment-12522427
This is the performance you can expect from a 570, HOWEVER, your low-end CPU would be lowering it's performance, so if you were to upgrade to a graphics card of this level or higher you will need to get a better CPU to unlock it's full power.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
https://linustechtips.com/topic/1059040-help-please/#findComment-12522488
Uhhhhhh... Can't answer that one chief.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12522511
27 minutes ago, theunwantedsorrow said:
@fasauceome will be able to play battlefield 5 or 1. And also thank you
oh definitely not, modern battlefield games are very hard on the CPU. Although if you get the 570 and later upgrade the CPU to Ryzen you'd do a lot better.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1059040-help-please/#findComment-12522529
@theunwantedsorrow This video may help you understand bottlenecks, it even talks about battlefield 1 at 3:12.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12522543
:D
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12522587
Some editing software uses one more than the other, but most of the time you need both to be good for optimal editing.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12525089
Those programs are more graphically intensive than cpu yet still need the cpu for support, if your mind is this stuck i would get the card and get a new cpu down the line.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12525510
If you need help I and others are here.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
https://linustechtips.com/topic/1059040-help-please/#findComment-12528309
