Hello I was just curious my second display which is my 1440p is refusing to display right. when I go under settings to try to change the resolution to the 1440p it only gives me the option to go up to 1024x768. Any advice or ideas? It was never dropped or anything and no water damage or anything along those lines.
https://linustechtips.com/topic/1059002-need-help/
do you have graphics drivers installed?
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1059002-need-help/#findComment-12520628
