Hey guys, I have a weird question. I got ripped off when I bought my pre-built computer and got a Radeon RX 560 2gb in it, as well as an FX-6300. I've since upgraded the mobo, the CPU, and the RAM, but now I need to upgrade the GPU. I've been surfing the internet for deals on a new GPU, but haven't really had any luck. Could one of you help me find a GPU that can get about 50-60 FPS in modern games at around $150 to $200? Thanks.
https://linustechtips.com/topic/1058898-gpu-help/
1080p? Maxed out settings or are you okay with dialing things back a bit?
Are you in the US? You would get more bang for your buck if you went with a used card.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519695
yep 1080p, games like The Division 2, Fallout 76 (open world) would prob have to be on high, games like Rainbow Six Siege, etc. would be maxed out. I'm in the U.S, and if it could be new, great. If not, thats fine, just needs to work.
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519703
Just now, alatron978 said:
yeah, cool. But Amazon has its downside.
https://www.amazon.com/ASUS-ROG-STRIX-RX580-O8G-GAMINGOC-GDDR5-Ready-Graphics/dp/B071D8YQJD/ref=sr_1_11?crid=2DHGS5TYCH9LE&keywords=radeon+rx+580&qid=1556415538&s=electronics&sprefix=radeon+rx+58%2Celectronics%2C231&sr=1-11
This used to be $210, and i was going to get this, but after a couple of days the price got jacked up, and it constantly keeps fluctuating. But, I will have the money in about 2-3 weeks.
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519712
like @alatron978 said a RX 580 or even a gtx 1060 6gb both would be very comparable.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814500454&ignorebbr=1
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519714
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519717
What are your new specs for these components?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519720
you know, AMD will be launching new graphics cards in a couple months. Why not wait and see what's to come in that time?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519726
CPU: Ryzen 2600
Ram: Balitstix 2x4gb 2666 mhz
Mobo: https://www.amazon.com/Ryzen-Gaming-Motherboard-B450M-CSM/dp/B07FKV5HWJ/ref=sr_1_17?keywords=asus+motherboard&qid=1556416050&s=electronics&sr=1-17
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519728
1 minute ago, CaptainCrawfsh said:
Nice, yea you would be good with 570-580 or 1060 6gb. Like I said used will get you more bang for your buck.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519737
Just now, CaptainCrawfsh said:
Can you explain what VRAM is?
VRAM is the amount of RAM the card has dedicated for processing graphics. It is used for a variety of things, most notably for storing and loading textures.
I would recommend this card for your budget:
https://www.amazon.com/dp/B06Y66K3XD
It has 8GB of VRAM, and goes toe-to-toe with the GTX 1060 for a little less cash and more VRAM. It's god-awful looking and consumes more power/outputs more heat IIRC, but it will get the job done for you.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519770
lol, yeah I saw that. At least it has a backplate...Thanks
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519773
Thanks everyone for your time and shared knowledge, but no offence, I might save up for this:
https://www.amazon.com/dp/B07P689CXR/?coliid=I201UJ8PV4KGYK&colid=9YCQ8F1AQ24P&psc=0&ref_=lv_ov_lig_dp_it
The other cards would work fine I'm sure, I just want to know I'm getting a quality new card. Plus it looks nicer...
https://linustechtips.com/topic/1058898-gpu-help/#findComment-12519781
