You want to upgrade your storage or your memory? either ways you wouldn't need a new key.
If you want to add more memory you just throw another RAM stick on it and done, if you want to replace your boot drive just clone your current one into the new one and also done.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1058747-hard-drive-upgrade/#findComment-12518383
5 minutes ago, piercetorres said:
I want to change the boot drive but how would I clone it
Clonezilla is one way to go, there are tutorials on how to use it on youtube... however you'd need an actual PC you can hook up both drivers to.
Personal Desktop":
https://linustechtips.com/topic/1058747-hard-drive-upgrade/#findComment-12518415
  • 2 weeks later...
