What are your specs?
Unless you're running other passively cooled parts, your psu and graphics card probably also have fans. Another component that can cause noise is the hdd.
https://linustechtips.com/topic/1058587-my-air-cooler/#findComment-12517196
4 hours ago, Void- said:
@WoodenMarker I'm not at home to check my specs but I dont have a graphics card I have looked and dont know how my pc runs without it
The motherboard or cpu likely has an integrated gpu.
https://linustechtips.com/topic/1058587-my-air-cooler/#findComment-12517580
On 4/27/2019 at 1:21 AM, Void- said:
My secound pc is realy loud and I looked in the pc and the only fan is the cpu fan, then i look at my temp and it says 70C. Is that bad?
70C at idle is terrible, but at load, it's fine. I'm guessing that you are talking idle temps though. So, yes at idle 70C is really bad, and you definitely need to fit some case fans.
https://linustechtips.com/topic/1058587-my-air-cooler/#findComment-12527982
