1 hour ago, Rogue-OP said:
If it's under warranty go through Asus. Anything you could do would likely void the warranty.
Depends, if ASUS screws around in customer service and warranty. Heard stories about RMAs and Warranty replacements. Didn't go so well, so like any others driven by fear... I stayed away from ASUS.
I'm greatly above potato, but I'm getting there...
Midrange Potato LVL 60:
CPU: Ryzen 5 3600 with Snowman MT-6 Dual Fans (CPU @ 3.8 GHz - 4.375 GHz to 4.5 GHz @ 1.1V - 1.35V),
MOBO: MSI B550-A Pro
GPU: Asrock RX 5600 XT Phantom Gaming D3 (1820MHz core @930mV)
RAM: TeamGroup T-Force Delta DDR4 Gaming 16GB (2x8GB) 3000MHz 16-17-17-37-58 @ 1.35V,
HARD DRIVE: WD 1TB Blue
SSD: Toshiba XG5 Series NVMe 512GB (KXG50GVN512G) & Crucial MX500 1TB
CASE: DeepCool Kendomen Titanium case
PSU: Corsair RM-750 (2019) 80+ Gold
Display: Asus VP249QGR via HDMI (144Hz)
Keyboard: Generic PS/2 Keyboard
Mouse: Generic Honeycomb 250Hz Mouse
Speakers: Generic Headset
And yes, there are now fans. 5 Arctic P12 PST's
Userbenchmark Run:
https://www.userbenchmark.com/UserRun/25234338 I don't trust that site anymore
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12510085
Could try rma. Or just deal with it.
Or try a better psu.
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12510306
5 hours ago, Mick Naughty said:
Could try rma.
RMA'ing an ASUS product due to coil whine? pff what are you thinking? they'll probably laugh at him and charge the mailing back xD
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12511264
Seems to be everyones go to answer. Ive never had an issue my self. I need to watch some videos of coil whine, still don't know what it sounds like.
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12511283
1 minute ago, Mick Naughty said:
It can be annoying, the only time I had hardware whine was on an extremely specific situation, whenever I launched The Witcher 3 on the initial loading of game before the main menu my old TITAN X Maxwell would whine like hell and it certainly was annoying.
Thankfully that was the only moment for whatever reason, if it happened often though I could see myself getting fed up with it, about RMA'ing due to coil whine though as far as I'm concerned unless it's EVGA you're likely to have a bad time managing the replacement... Specially if it's ASUS... their RMA/Costumers Service really is lackluster sadly...
Personal Desktop":
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12511293
25 minutes ago, adambruzz said:
The psu is a Corsair RM1000x,
it will be be the last Asus item I ever buy, iv had nothing but issues with them lately
So the house has clean power?
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12511317
so i tried another 1080ti this time a gigabyte extreme one, the coil whine was just as bad could it be the psu instead it is a corsair RM1000x 3 years old now
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12512231
Yea I imagine it doesn’t whine at idle.
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12512633
47 minutes ago, adambruzz said:
Nope not at idle
Which would explain what you just did. 30 frames isn’t enouhh use to effect the inductors obviously.
Id still try another psu as the Ltt video suggests.
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12513066
I used my friends 2080 that had no noise in his system but did in mine so yeah
which power supply would be good though
currently got Corsair RM1000x
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12515005
Just filled puller psu out of the case and it’s deffs coming from GPU even with this 2080 I’m it
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12515080
Any thing that isn’t the same brand. Idk what people are getting nowadays.
I got an evga unit. Not a lot of options for me.
https://linustechtips.com/topic/1057744-1080ti-issues/#findComment-12515490
