A few things.
The intake to your reservoir is on the top. The coolant rushing through the air at the top might be aerating itself by passing through the air space. Try removing more airspace, or running the intake to the bottom of the reservoir (this would be the optimal method). Thicker coolant with additives (i.e. what you're using with that dye, as opposed to straight distilled water) will shed bubbles less quickly and tend to build up foam.
You may have had air left in your radiators after filling it, which is slowly bleeding into the coolant and causing the bubbles.
You could have a loose fitting somewhere, sucking air in and making bubbles.
It will more than likely take several days for the air to dissipate, provided your loop is not creating or exacerbating the issue.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
https://linustechtips.com/topic/1057666-custom-loop-issues/#findComment-12508516
if its recently filled loop its possible the bubbles will slowly disappear, but the easiest way to deal with that is it just fill the res up.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1057666-custom-loop-issues/#findComment-12509902
Where is there actually air at in the loop? A res doesn’t count.
Let it settle and turn the pump speed down.
https://linustechtips.com/topic/1057666-custom-loop-issues/#findComment-12510130
