Okay guys so I have a question , in some games actually most , my cpu temps jump like crazy from 40 to 50 , 50 to 70 , 60-90 but fast they go back n forth n I noticed something weird w resident evil 2 remake the temp stays steady like the gpu temps .. was at 50 most of the hours I played would go down or up 1 degree every now n than but nothing like other games that keeps the temps jumping every second why is that ?
https://linustechtips.com/topic/1057394-cpu-temp-question/
Since your FPS is reading 60, seems like VSYNC is enabled which is keeping your load at a constant rate instead of wildly varying as a result of the game loads.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12506123
It literally says it on his screenshot ‘G sync on’
i assume he has it on in all games. If so, doesn’t explain the temp jumps.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12506204
Gsync is completel different than Vsync. Vsync locks your refresh rate to your panels refresh rate. Gsync smooths out your frames to when in between a certain range to prevent screen tearing from the frames becoming out of sync.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12506212
I have g sync enabled , v sync on in nvidia panel , v sync off in game , reason is I play in a 4k 60 hz monitor .. n if I turn off v sync nasty tearing I get .. but yeah my cpu temps just crazy up n down on most games except RE2 remake
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12507217
Nvidia panel will trump any in-game setting. Gsync is what was developed to resolve tearing. Turn off vsync and just let Gsync do its job. its why you paid the premium for Gsync.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12507327
My monitor has FreeSync but if I turn off v sync IN NVIDIA PANEL & IN GAME I get really nasty tearing .. it seems the only way I can play smoothly is w v sync on in nvidia panel & off in game
https://linustechtips.com/topic/1057394-cpu-temp-question/#findComment-12507347
