My PC Randomly Freezes When I Turn On Any Game Or Any Program Like Premier Pro Or Discord. It Might Take A 30 Minutes Or 2 Seconds Then It Freezes In The Strange Way. When Frozen I Can Still Hear The Audio But Display Fezzes, So I Can Hear Everything And Can Move My Cursor But Clicking Doesn't Do Anything.
So Far I Tried:
 A Different Monitor
Disconnecting My Pretrials
Running Stock Clock... Same Problem
Update!!!
So I Was Determined To Swap My MoBo And I Found A Little Corrosion On My Graphic Card. See The Pictures Bellow. Can This Cause Formation Problem?
System Specs:
Case:              NZXT H440 RAZER EDITION
Motherboard:  Asus Deluxe 2
CPU:               Intel I75930k 3.5 GHz
RAM:              Corsair Dominator Platinum DDR4 16 GB (4x4 GB) 2666 MHz
Graphics:        EVGA Nvidia GTX 980 Ti FTW 6 GB
PSU:               EVGA Supernova 850 80 Plus Platinum
NVME:            Samsung 970 EVO 500 GB
SSD:               2x Samsung 860 PRO 512 GB Each
HDD:              WD Green 1 GB
Cooling:         Custom Water Cooling Loop
Monitor:          ASUS 27" ROG Swift PG278Q
Edited by BRAVO 6
Update
https://linustechtips.com/topic/1056745-pc-randomly-freezes-help/
1 minute ago, piercetorres said:
Try upgrading the ram I saw you only have 16 gb
16GB is more than enough and should not cause his PC to freeze.
OP, seems like possibly a GPU issue because if you're getting audio is seems like a lost of display output. Maybe try reinstaling display drivers? Or if you have another GPU, see if the system locks up using that.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
