External GPU power brick
Solved by Ross Siggers,
11 hours ago, DarthSmartt said:I am working on an external gpu project for my laptop with a 1070 that i have. I wanted a psu without all of the wires and such. The 150w 360 one had the power specifications i needed. I figured I could splice the +12v and the grounds together on an 8 pin connector.
If you're using a EXP GDC dock for your project, you can simply get a psu that has an 8-pin connector on it already; Google for the Dell DA2 power brick, its 220W and should be enough for almost any dedicated graphics card
