How do I connect a molex cable
Kokomo
Hi
i have a Corsair rm 750x psu and I am trying to figure out how to connect my hue +2 as it uses a molex cable for power. It says that it should connect to the pus’ molex but I’m not sure what I’m supposed to do. It’s been a long day so may be missing the obvious i see that it does have molex cables but not sure how they connect as they have a type 3 connector on one end .This is the Last thing I need to finish on my new build so any help is appreciated.
thanks
Current rig
NZXT S340 Elite
Kraken x62
Gigabyte Aorus WIFI Pro
32gb 3000mhz corsair Vengeance RGB PRO
I7 9700k
Rtx 2080 asus strix
1tb samsung evo ssd
1tb wd hdd
samsung 27” 1440p 144hz monitor
On one side of the molex the pins are kinda at an angle. You gotta just check if they are oriented the right way and if a pin pushes out a bit push it in with a tool screwdriver obv when the pc is off. Ittl need a bit of force but not too much. You can do it.
Hi
I plugged them into the psu then connected the two molex but the fans arent lighting up have i put them in the wrong connection on the power supply or something else. The conenctions where called peripherals and sata will have a look into the software if it recognises it. The fans obviously spin but no lights
Current rig
NZXT S340 Elite
Kraken x62
I7 9700k
Rtx 2080 asus strix
1tb samsung evo ssd
1tb wd hdd
4 hours ago, Kokomo said:
Hi
"Molex" is a brand.  The correct name for the four pin connector is "Peripheral Connector"
The connection on the PSU is labeled "Peripheral/SATA" and it has six pins.  A cable with a six pin on one side and a number of "Molex" connectors on the other was included with your power supply.  The six pin, which will probably be labeled "type 3" or "tpye 4" plugs into the PSU.  The other end plugs into your HUE 2.
You have the rest of the PC built up, right?
