RMA Help
Go to solution Solved by Slottr,
12 minutes ago, Tamesh16 said:
So would i just need to send request to dell support and talk to the service agent about getting it replaced/repaired ?
and if so everything about my argument seems solid for a rma right ?
also thanks, cause i was worried since i threw the box away every since
IIRC, there's a portal you can go to that will let you submit a ticket. Though yeah you can probably talk to an agent.
And absolutely! Swollen batteries definitely make you legible for an RMA
So i have never sent back hard ware, but my current laptop, i bought last summer, is giving trouble
at first there were driver errors1 were would crash often but then that eased off as time went on
then i started to notice power problems2, where couldnt detect the power of charger and crash
but recently , actually this morning saw that battery is fully swollen3, its 99wh battery
and system is still in warranty, i know i can send it back , but how do i go about doing this ?
i have the right to request a new laptop right?
given that they were defects in system?
also i dont have original box it came in would that be a problem ?
specs for laptop in my signature
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1056546-rma-help/
You need to contact your manufacture of the laptop to start the warranty/RMA process.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498630
You'll send an RMA request to dell, then when they approve it they'll they'll walk you through the process
You won't need the box
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498633
Contact Dell, they will run you though some troubleshooting and general question. They will give you a ticket number and setup for a box to be sent to your house, it should have instructions on how to pack the laptop into the box and have a return shipping label. Make sure you tell them all the issues not just the swollen battery.
Sometimes they will just pull you storage media and swap it to a different machine. Sometimes they will just fix the issues.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498635
so the thing is , i actually did tell them i was trouble shooting with dell support since i got it, so i can always reference those cases, however i will make sure to bring it up again
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498651
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498654
Absolutely you shouldn't experience a swollen battery while under warranty, is 100% covered.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498657
Thank you, thats a relief , its a bit heart wrenching, i spent like US $1700 in this machine, so i really just want it to be replaced, so i wont have to worry about these issues anymore
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498661
Yea, I know how you feel years ago I spent $1,400 on a HP and within 3 months i would no longer charge, the 2 usb ports that were direct on the board were dead and the top plate under the mouse button had broke causing the buttons to sink in. I RMA'd it they wanted to charge me almost $300 for everything besides the charging port. I was like FU and fix the charging port only so i can at least use it and threw a big fit at them about it. Got it back and it charged for about a month until it stopped again I contacted them again and threw another fit. They ended up replacing the entire machine besides the two HDDs which they swapped.
That was the first and last HP I will ever buy.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498668
I am sorry to hear that, to be honest with alienware i was never expecting these kind of issues, but i guess this comes with  buying hardware in general
i hope your laptop was usable by then end of all that ordeal
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498676
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498682
It was and I quickly got rid of it not long after I got it back, I ended up going with a Dell 15" 7559 with 4k touch and i7 machine. I have had this laptop for little over 3 years and not one issue and for almost 2 years it was my only PC and it was on 24/7 hosting plex server ect. Has been a great machine.
It happens sometimes but I know dell will do you right.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498683
Thank you both for your help, @ddennis002 and @Slottr , i will  contact and start the RMA process, hopefully it all works out for the best
Cheers Guys !
https://linustechtips.com/topic/1056546-rma-help/#findComment-12498687
  • 7 months later...
Cheers Guys !
Just curious as a follow up @Tamesh16 how did the RMA go?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1056546-rma-help/#findComment-13072337
It went well actually, they sent a box for me to pack the laptop in and paid for everything, however they chose to repair it instead of replacing
but i have been using it for a while and its working much better so i didnt really mind
https://linustechtips.com/topic/1056546-rma-help/#findComment-13072386
Thats good to hear.
I just ordered a replacement battery for mine it finally won't charge anymore 3 1/2 years old so its defiantly time.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1056546-rma-help/#findComment-13072393
