Hello guys, today when i turned on my pc it appeared with strange colors and some horizontal tiny stripes. I have the newest driver and i reset my monitor settings to factory. I need your help :)
Monitor: Alienware AW2518HF
Graphic: GTX 1070
Processor: I7 8700
RAM: 16GB
Connected via DP
https://linustechtips.com/topic/1056169-i-need-help/
This almost looks like interlacing + 6 bit colors combined..
Did you check if all your Nvidia/AMD settings are correct in the driver? Specifically the resolution and color bit depth settings. If you start your monitor, does it perhaps saying anything like "1080i, 60Hz, 6 bit" or something like that?
Otherwise, any possibility you could check with another cable?
https://linustechtips.com/topic/1056169-i-need-help/#findComment-12495011
Man, i was pissed of a lot and i started to clean my room, after 15 min when i finished up i turned up my pc and magically it’s normal again. I don’t know what was the problem. Thanks fo advice again
https://linustechtips.com/topic/1056169-i-need-help/#findComment-12495038
