Did you recently upgrade from an earlier version of windows?
Try:
1) Reboot your computer
2) Run your application as administrator
3) Reinstall your application
4) Reinstall Microsoft .NET framework (for Windows 7 or below)
5) Reinstall Microsoft Visual C++ Redistributable Packages
6) Update your Windows
7) Run check disk
Also could you provide more details about the issue? Your post is aggressively vague.
https://linustechtips.com/topic/1056007-i-have-a-problem/#findComment-12493763
Try:
7) Run check disk
I done all that but nothing works it keeps saying that and not I had this windows for a while I been updating it it’s up to date but idk what else to do
https://linustechtips.com/topic/1056007-i-have-a-problem/#findComment-12493777
Troubleshooting steps that you have attempted and that have failed are great things to put in your *single* original post.
What are your specs? Is this the only program you're having this issue with? What version of windows are you running?
Please provide more details. All of your posts about this issue remain aggressively vague.
If you want more people to reply to you and help solve your issue in the span of 5 minutes, try editing the original post to provide more detail instead of posting an additional even less detailed post.
https://linustechtips.com/topic/1056007-i-have-a-problem/#findComment-12493787
Please provide more details. All of your post about this issue remain aggressively vague.
If you want more people to reply to you and help solve your issue in the span of 10 minutes, try editing the original post to provide more detail instead of posting an even less detailed post.
Ok well my specs I have a rx580 ryzen 7 1700 16gbs ram asus b350 750watt 1tb hard drive and yes that is the only program that I have problems with the is windows 10
https://linustechtips.com/topic/1056007-i-have-a-problem/#findComment-12493793
When does this happen? Are you attempting to load the launcher? Load a game? Was it working fine and then just stop?
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1056007-i-have-a-problem/#findComment-12493864
