NEED HELP WITH MEMORY
Go to solution Solved by Windows7ge,
With the CPU itself it isn't so much a concern as anything above what the CPU supports natively will technically be an overclock. This is fine. X.M.P. usually does this for you when enabled.
Hello all
I am building an AMD pc, not sure the ram selected will be compatible with the processor.
 these are the specification
amd ryzen 2700
asus b450 plus
 and this is the ram i selected "Corsair 8GB DDR4 CMK8GX4M1A2400C16R" 3000mhz
will this be compatible with the amd 2700?
 please help
https://linustechtips.com/topic/1055883-need-help-with-memory/
It should be compatible, Should be is the key term here
(Take anything I say with a grain of salt)
[Main Pc] CPU, i5 9600k GPU, Asus Strix RTX 2060, RAM, 16b Team Group Delta RGB, PSU, Seasonic Px-750 plat , Cooler, Cooler Master MasterLiquid Lite ML120L RGB, Storage, 500gb Samsung 950 evo/1tb WD blue/2tb HDD,Case, Enermax ECA3520. + some cooler master RGB fans
[Laptop] Dell G3, i7-8750H (Turbo 4.2 Ghz), Gtx 1050 ti , 8gb 2669 mhz, 128gb nvme ssd, 1tb HDD
[Server]
[Consoles] Pretty much almost every popular one you can think of besides for like Xbox and some Sega Stuff( Playstation especially)
[Mobile Devices] iPhone XR 64gb (Red) gb, iPad Air 2 128gb, Space Grey,  Ipod Shuffle Space Grey
https://linustechtips.com/topic/1055883-need-help-with-memory/#findComment-12492517
https://linustechtips.com/topic/1055883-need-help-with-memory/#findComment-12492526
From what i have seen till now with those AMD CPU's, 3200Mhz is the sweet spot
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1055883-need-help-with-memory/#findComment-12492636
