Yo!
One fast question: No matter what settings are set in windows or bios, the power light will be lit on the gpu if its working?
-Having issues with second gpu in second PCIe slot, its not detected and no power light is lit.
-Since i just finished a custom water loop on those two cards, I really dont want to take em out to look for errors if I dont need... :/
Crosshair VI Hero
AMD Ryzen 7 2700X
G-Skill FlareX 16GB 3200Mhz
2xVega 64
Corsair HX1200
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/
Sounds like the load indicator doubles as power indicator. So both were confirmed working, right.
Either the card is dead for some reason. Probably static.
There is a missing connection somewhere.
Or there is a compatibility issue.
Try (if possible) to have just the second problem card installed and powered. If the system boots, we can assume there is some type of compatibility issue.
-アパゾ
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12490916
When i try with the power cables disconected from GPU one ad have the monitor cable on power cable conected to GPU2 (the trouble one), when i start the pc then the monitor detects a signal and turns on, but after a couple of seconds it goes back to sleep mode...
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12490967
I don't see what the issue is.
The PCB has flex, just enough to allow the card to sit next to the slot.
It's a tedious maneuver with both cards watered but it can be done. I've done it on more than one occasion with client PC's.
-アパゾ
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12491155
1 hour ago, Seizan said:
No dual card blocks, just made a tube from top card to the next one. The water loop is very custom made, as shown in the pic lol. there is also show what i mean lamp lit on gpu 1 but not on 2.
-- Big picture snipped out --
Check the PCI-E power connections on the top card.
I can't see it very well in your picture, but it looks like one of the PCI-E connectors is not in properly.
Also, when running the GPUs in Crossfire, you're suppose to connect your monitors to the PRIMARY GPU (e.g. the top one).
The second GPU functions as a "slave", and the output ports are disabled.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12491266
Got second card tested in first PCIe slot, and it works. So that makes it an MB issue or some software thing.
Thing is now i might have fuked things up, when i going to put the cards back i acidently pulled them a part, and result was ofc cooling liquid flowing out!
Atleast i had pulled out power cord from PSU before i started this, but.... guess i'll see how stuff are after i get it dryed up lol
Dont do this at home >>
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12492215
So it was all tested prior to the build?
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12492482
Test the good card in the other slot.
https://linustechtips.com/topic/1055703-do-my-gpu-work-or-not/#findComment-12492847
