I am planning to buy Magnetic Cable Organizer:
https://www.aliexpress.com/item/Magnetic-Cable-Organizer-For-Mobile-Phone-USB-Cable-Management-Clip-Data-Cable-Organizer-Wire-Cord-Holder/32950649406.html?spm=a2g0o.cart.0.0.987d3c00Hvb6To
Can magnet that will come around cable interfere with cable normal work? I will use usb cable and audio extension cable for this.
https://linustechtips.com/topic/1055674-magnetic-cable-organizer/
It should not interfere. You should be all good
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
It wouldnt interfere, i have something like this i use for holding phone and kindle chargers on the side of my desk, no issues, also used it on an audio wire (TRS i believe) with 0 issues.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
