Graphics card is compatible, yes
But don't get that power supply, grab a decent unit. Where are you from?
https://linustechtips.com/topic/1055477-help-pls/#findComment-12488833
can you suggest recommended PSU for this GPU ... i'm from philippines and the PSU available in online shops here are either Corsair or EVGA...my friend suggested the SeaSonic...
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489247
The thing is, you should never buy by brand but by model.
What Corsair and EVGA unites (or even Seasonic ones) that are 80+ Gold can you afford on your region?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489253
2 minutes ago, RJSiGAMING said:
only bronze is available here :(
That's troubling, most bronze units makes serious compromises in build quality that makes the power supplies become a greater risk to your system and it's own longevity.
With that said, can you still list your options so we can advise you the best unit out of the bunch?
Keep in mind you only need a 500w~ ish PSU.
Personal Desktop":
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489262
i also have another issue to ask... i have 2 different RAMs both 8GB 2400 from avexir and gskill respectively... and i'm planning on upgrading my proc and cpu to a Ryzen 5 2600x/b450 aorus... won't it have problems if i used those RAMS?
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489280
Ryzen is very memory sensitive, while it's likely to work keep in mind your memory overclocking might be limited and Ryzen really needs fast memory to get the most out of it.
Personal Desktop":
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489282
what can you suggest for RAMS on the B450 Ryzen 5 combo?
https://linustechtips.com/topic/1055477-help-pls/#findComment-12489293
