Howdy fellas. I've got an old Asus P7H55 motherboard with damaged traces from improperly installing a cooler (just a board I mess around with. didn't have the mounting bracket and said fuck it). The board still works, however, memory channel B doesn't function properly. It will detect ram in those slots but it will not be usable. I've attached pictures of all the spots with issues, and idea's on how to fix that? thanks!
Images:
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1055395-fix-damaged-pcb-traces/
Soldering wires to connect the damaged bits... Dont see you actually doing it lol, motherboards dont cost enough to be worth fixing like that
Desktop benching:
https://linustechtips.com/topic/1055395-fix-damaged-pcb-traces/#findComment-12488119
While it might be possible to remove some of the solder mask and solder a bridge wire across the damaged sections, I wouldn't bother.  One, you are likely to cause even more damage in the process.  Especially if it's your first time attempting the repair with some very delicate traces.  Two, did you notice those traces are all squiggly?  They do that so that all of the high bandwidth traces are exactly the same length even though they are going to different pins on the RAM.  They have to be the exact length because at those frequencies you can get a lot of timing errors if they aren't the same.  A repair will likely change the length of the repaired traces and even if it does detect the memory and make it usable again, you're likely to start getting weird issues after running your system for awhile.
Either keep using it as is, or buy a new (used?) board.  That board is less than $50 on eBay.
Malo Periculosam Libertatem Quam Quietum Servitium
https://linustechtips.com/topic/1055395-fix-damaged-pcb-traces/#findComment-12488165
Thank you for the replies. This board is used in a "project computer" of sorts. It serves no practical use but I've done some good overclocking with it and have modified the case to provide better cooling. A DIY repair on this board could provide a good learning experience for me so I'd like to do it myself.
What are your thoughts on a conductive pen as shown in this old LTT video? Seems it would be tough to be accurate enough with it, but I've considered giving it a shot.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1055395-fix-damaged-pcb-traces/#findComment-12488208
Not good enough for repairing something as dedicated as a motherboard, let alone one related to memory. It can probably fix a raspberry pi, but not a desktop.
Desktop benching:
https://linustechtips.com/topic/1055395-fix-damaged-pcb-traces/#findComment-12488218
