hi guys just a quick question
planning on building a AMD based mining build for a friend
its gonna be caseless so what good quality risers are there ? ive seen some reviews that bought bad quality risers that break so can you recommend me one that also cheap ? x16 to x16  preferably on amazon.com or ebay.com
also here are the specs
GA-990FXA-UD5
low end quad core or maybe dual
4GB ddr3 ram
four 290 GPUs (non reference cooler  )
1300 watt corsair PSU
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/105514-mining-build/
GA-990FXA-UD5
4GB ddr3 ram
I'd suggest that you should go for an intel cpu
something like this "combo"
CPU:  Intel Celeron G1820 2.7GHz Dual-Core Processor  ($46.86 @ OutletPC)
Motherboard:  ASRock B85 Pro4 ATX LGA1150 Motherboard  ($77.55 @ Newegg)
Total: $124.41
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-22 08:20 EST-0500)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/105514-mining-build/#findComment-1410838
Total: $124.41
im buying the parts locally
and those arnt available here
https://linustechtips.com/topic/105514-mining-build/#findComment-1410849
ok then, but you still don't need that motherboard
any motherboard with 4 pci slots will probably work
https://linustechtips.com/topic/105514-mining-build/#findComment-1410889
Total: $124.41
he would have to put two cards in x1, not a very good idea imo.
https://linustechtips.com/topic/105514-mining-build/#findComment-1410903
why? the card's won't have enough bandwith?
https://linustechtips.com/topic/105514-mining-build/#findComment-1410913
yes, I saw that page just before responding to your last comment. that's why I asked you.
https://linustechtips.com/topic/105514-mining-build/#findComment-1410934
yeah, you would have x1 bandwidth. i wouldnt recommend that.
from what I've heard you don't really need a lot of bandwidth for mining
https://linustechtips.com/topic/105514-mining-build/#findComment-1410972
GA-990FXA-UD5
4GB ddr3 ram
As I said yesterday, you'll need more power. Remember that 1300W psu doesn't give a net 1300 W power output. Since you need 300W per GPU, + maybe 150 for the rest (mobo, cpu/apu, fan, HDD) you should go with 2 PSUs.
Go back and read the thread : http://linustechtips.com/main/topic/104577-quad-280x-cards-without-risers/
As for the risers, just beware of the chinese risers on ebay which are pretty cheap. Keep in mind you'll probably burn a few doing tests so buy spares. If you're knowledgeable with solders, you can try to CAREFULLY repair those burnt risers. Also, buy POWERED risers. Use the same PSU to power one GPU AND its riser.
https://linustechtips.com/topic/105514-mining-build/#findComment-1411134
