Not sure if this is the right area to post but basically im wondering if 8% cpu usage is normal on idle
The second i open up my task manager, it's 56% then 10, 12, then 8%, is this normal? Im on performance mode and my cpu is the i7 8750H, i'm afraid i have a virus so please clarify, thanks
https://linustechtips.com/topic/1054801-cpu-help/
Can take screenshot of the task manager process tab with cpu column sorted from high to low?
https://linustechtips.com/topic/1054801-cpu-help/#findComment-12482822
You're fine
https://linustechtips.com/topic/1054801-cpu-help/#findComment-12482823
