4 minutes ago, LeapFrogMasterRace said:
What is your native resolution? You should be able to hit 100fps at 1080p in games that are not too demanding using x264
my native res is 1920x1080. But I run 2 monitors
plan on streaming fortnite and apex
https://linustechtips.com/topic/1054770-help-on-streaming/#findComment-12482607
The additional monitor wont affect FPS by a noticeable amount unless you are using hardware acceleration to watch a HD video or something. Those game are easy to run but you might have to turn down a few settings in apex to always say above 100fps
https://linustechtips.com/topic/1054770-help-on-streaming/#findComment-12483609
Depends on what you do and the quality you expect. Apex won’t be so great on decent settings.
https://linustechtips.com/topic/1054770-help-on-streaming/#findComment-12483881
I don't play much apex. But I wanna stream on epic settings at 1080p 60 frames, till I get my streaming pc up and running.
https://linustechtips.com/topic/1054770-help-on-streaming/#findComment-12484170
