Building my first pc
Go to solution Solved by Fasauceome,
15 minutes ago, RobFRaschke said:
Ah, I couldn't find the Q300L for some reason, that's practically as good a case as the meshify for 1/3rd the price over there, go with that.
A 275GB SSD is not big enough. he wouldn't even be able to get the games he listed on it, let alone an OS and some files.
I was going for performance first, 1440p 144Hz is more demanding than 4k and I figure an HDD can just be thrown in later.
21 minutes ago, AVSHedgehog said:
is this going to get at least 144fps at high settings consistantly on games like cod gta far cry etc?
for the most part, yes. You'll be seeing likely above 125 FPS regularly. Or at least, on COD (depending on which one) and GTA for sure.
Okay so my limit is $1500 aud so $1075.42 usd. I want to make a black and white pc that can run cod,virtual reality,cs go, rainbow six seige, far cry etc on high settings at144 fps at least. I also want it to be future proof for at least 5 years. so please leave some links on pc part picker thx.
Edited by AVSHedgehog
better tags
https://linustechtips.com/topic/1054653-building-my-first-pc/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481488
1440p 144hz on farcry on high, not gonna happen, but at that budget r5 2600+2070 is the best ur gonna get, not gonna last 5 years, maybe u can wait a few months for zen 2.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481507
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481525
Primary PC:
PSU tier list
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481555
If you could spend a tiny bit over the 1500, you could get this:
Get Vega over the rtx 2070, because that will 'futureproof' better because of HBCC. At 1440p, you ain't gonna last 5 years with 8gb vram, not at ultra/high anyways. The vega card performs close to the 2070, but it's much cheaper and you get a better cooler. The other advantages of this build are the 1tb ssd, far more space than that 275gb, and also a far higher quality power supply. I used a silverstone case cause their cases are always really strong for airflow, which will help with the heat of Vega.
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481641
I think somewhere in the middle of all these, we have a really good build, lol. I've tried to pick and choose the best parts of each that will hopefully fit in the budget, and gone $40 over, but I think it's absolutely the best you can do for the $$$$. The ASRock board is $20 cheaper, but only has two ram channels, and that's against your 5 year plan IMHO. Also, I couldn't reccomend a SSD under 500GB, and the 1TB is faster, but if you needed to shave those few bucks, you absolutely could shave them there.
You're also going to want more fans, so you can run them all at lower speed and get enough air through the system, and may want to upgrade from the stock CPU cooler, but those can be done here and there, when a few extra bucks comes your way.
https://linustechtips.com/topic/1054653-building-my-first-pc/#findComment-12481935
