4 minutes ago, randyzz said:
so im building my  own pc and i just got my 450 w psu i dont know hif it will work with my pc
my pc specs are
https://pcpartpicker.com/list/
That's the wrong link
but unless it's Vega 56 and an 8 core intel CPU it'll be fine
most gaming PCs won't draw over 300W at load if it's a 100W CPU and 150W GPU
That liink just brings you to your last viewed list if you have a PCPP account.
I was hella confused when I thought you asked if you could power a Ryzen 9 and Radeon VII with a 450w PSU o_O
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
6 minutes ago, randyzz said:
Are you in the US? because you should change everything but the CPU pretty much
10 minutes ago, randyzz said:
y
Because you should/could be getting a better motherboard/GPU/RAM and power supply,
PSU pricing is high atm across the board. There's also a 2017 model for less than your 2015 model, I wouldn't trust mail in rebates to work.
also there's no case or storage?
You can just use the stock cooler for a while if necessary.
PCPartPicker part list: https://pcpartpicker.com/list/Dw6g6s
Price breakdown by merchant: https://pcpartpicker.com/list/Dw6g6s/by_merchant/
CPU: AMD - Ryzen 7 1700 3 GHz 8-Core Processor  ($159.65 @ Amazon)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard  ($87.88 @ OutletPC)
Memory: Crucial - Ballistix Sport AT 16 GB (2 x 8 GB) DDR4-3000 Memory  ($78.69 @ Newegg)
Video Card: ASRock - Radeon RX 580 8 GB Phantom Gaming X Video Card  ($169.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 450 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($56.98 @ Newegg)
Total: $553.19
Generated by PCPartPicker 2019-04-13 21:35 EDT-0400
