Hey everyone I’m new to this site and I’m a beginner tech so any help/advice is appreciated! I am having a issue with my graphics card. I have a Asus ROG laptop G750 series it’s about 5 years old. It was working fine then I went to update my graphics card and I keep getting update can not continue. The card is not being detected in device manager I’m getting a code that says it’s not connected to the computer (error 45) it’s not so simple as popping it open and reseating it cause it’s a laptop and integrated. I have tried uninstalling and reinstalling the drivers manually but I get a error message says there is no compatible hardware on the computer. I tried to roll back the drivers to no avail I have tried a roll back the whole system through system restore and also the fan is constantly running on high like I’m playing a game but I’m just doing mundane tasks. It starts running high from the minute you turn on the computer. The graphics card is a NVIDIA GeForce 860M windows 8.1
https://linustechtips.com/topic/1054340-gpu-problems/
that's what happens when your GPU quits. Maybe the chip itself is dead and doesn't start (not even reporting error to the motherboard), maybe the VRM doesn't fire up so it doesn't get power etc
Desktop benching:
https://linustechtips.com/topic/1054340-gpu-problems/#findComment-12478722
This is what I was afraid of. Is there anyway I can fix this? I’m thinking of sending it in for repair but would they even be able to repair it since it’s integrated?
https://linustechtips.com/topic/1054340-gpu-problems/#findComment-12478726
you probably can't
if the GPU itself is smoked then they can't, because they most likely dont have spare 860M GPUs to replace with. Even on GPUs that are available, removing the solder and soldering the new GPU back in is a lot of work and usually not worth repairing if it's out of warranty
Desktop benching:
https://linustechtips.com/topic/1054340-gpu-problems/#findComment-12478783
