This really isn't a place to find such a specific part. Just google that part number and see who if anyone has it in Australia.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/1053618-i-need-a-part/#findComment-12471760
9 minutes ago, Professor G - Games - Tech said:
I need HP part number 729230-001. It is for an all in one.
It needs to be in Australia.
I already tried HP and they aren't for sale...
Thanks
What are the components of the PC? because unless it's a proprietary motherboard or PSU you can just replace it with anything else.
https://linustechtips.com/topic/1053618-i-need-a-part/#findComment-12471764
  • 3 weeks later...
@Professor G - Games - Tech
I posted your part number in new egg and it came up with the MOBO for around $88 I am however in the US. So your milage may very
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
    Corsair pro rgb 16gb 3400 oc stock timings
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
    My digital ssd 250gb pro m.2 (boot) 2tb berracuda 7200rpm +Toshiba x300 4gb 7200rpm
  • PSU
    Evga g3 750
https://linustechtips.com/topic/1053618-i-need-a-part/#findComment-12520958
