Passive Water Cooling?
This theory is exactly why I built my first watercooled system back in 2008. Back then I had 3x AMD 7970 in tri-crossfire config along witha de-lidded 3770k.
The noise was enough for me to not want to game at all at night, it was crazy. Those old AMD cards were crazy loud!
So i set about building a system with enough water that it would take a long time to saturate the loop with heat and it would in fact stay silent for a very long time.
I chose a 1260 external and a 380 internal to do the job.
It worked really well, with the big rad fans being virtually silent on full tilt anyway. The fans you can fit on internal radiators are far too noisy, but I had a few of them on the 380 too and they came in if the GPU out to large radiator out delta got too low and temps into rad 2 were getting a little too high.
This was all set up via an aquaero pro, the aim being to keep the fans off as long as possible.
Worked perfectly. If I was just browsing the web or working, the fans NEVER came on. If gaming something light I could game for around 45 mins before they even span up slowly.
HWBot benching I just enabled them all with an override, because 1c matters when you are geeking... lol
