Need Ultimate solution for GPU
Go to solution Solved by Bubbles_TPB,
dual 2080ti all the way for gaming
btw, it's like a $2500 US investment.
Single 2080ti. Dualcard configs are silly. Not inly are they a waste if money, but also doesnt benefit much in games.
Dont get the Titan unless you are doing compute or different workloads.
Thnx for your co-operation
I appreciate it
Bdw I thought rtx Titan have massive amount of ram so I thought , it would perform better
Ohhhhh I c
thnx for ur guidance
If you are looking for a Vram intesive workload or s compute workload that can use OpenCl. But since its gaming, anything more than single 2080ti is silky
