Help load
Solved by Jurrunio,
isn't that what you want? Otherwise there's performance you're not using.
Also running the CPU at 100% load is totally fine, that's its intended use. That software is talking crap
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
