Which fan is better?
Go to solution Solved by rentaspoon,
can you recommend a really good red vinyl dye, and also, for the nf-f12 are the blades removable, because I read that the blades to a different noctua fan are not removable. Also, can i remove the rubber corners for the painting process or will they break if i try to remove them?
The only problem vinyl dye from cheap to expensive is fade and bearing in mind its in a computer case you won't have much problem with fade. Just remember that its dye so you can go darker but if you want to go brighter you may need to put a light coat of white dye on first.
It sounds like a lot of work but its not, the dye dries quickly, the only prep is cleaning it free of grease and you can normally get a fan done in an hour plus 24 hours in cold conditions to allow the plastic to harden again.
From all of Linus's videos and some other places I have heard that the noctua NF-F12s are great, but they dont match my red and black color scheme. I like how the Corsair AF120 performance edition fans look. Could you tell me which fan you think is better and why, and if you don't want to answer that question than could you list some pros and cons of both.
Thanks in advance
https://linustechtips.com/topic/105332-which-fan-is-better/
Buy NF-F12's and paint them...? :D
Best performance with a great look.
No painting them would off balance them and would make them perform worse than intended.
NF-F12 are really good at pushing a good amount of air at a relatively low RPM compared to most fans.
I don't like AF120s because they are loud and don't push as much air as Noctua fans, but they are the better looking fan.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1408596
I use Corsair AF fans and they work fine for me. I also have a red and black color scheme so I would just recommend going with those.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1408598
Vinyl dye then? Soaks evenly into the plastic rather than changing the pigment
Yeah usually if someone wants to change the color of the fan, dying the fan is the best way so it won't affect the fan.
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1410867
Are they loud, like these people are saying, and what type of rig are you running?
They don't seem that loud to me but I also don't have them running at high rpm. My rig is on my signature.
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1410874
The SP120 are loud, I don't understand why anybody buys them. And AF120 are fairly quiet, but they don't move that much air. AP121 are a better choice if you don't want noctua, but in the end nothing beats a noctua and is silent at the same time( I mean, you could get a delta fan, and that would beat a noctua in performance)
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1410875
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1413136
https://linustechtips.com/topic/105332-which-fan-is-better/#findComment-1415484
