My setup:
CPU: i7-4790k
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition
Motherboard: MSI Z97 Gaming 7
RAM: HyperX Savage 16 GB (2 x 8 GB) 1866 MHz CL9 DDR3
GPU: MSI RTX 2070 GAMING Z 8GB
HDD: WD Black 1TB
SSD: Samsung 860 EVO 250 GB
MONITOR: Samsung 1080p 24" 60Hz
___________________________________
How much Watt PSU would I need for this system, and do you guys have any Budget / Mid-Range recommendations?
https://linustechtips.com/topic/1053154-psu-help-and-recommendations/
550 or 650w will be fine for your build.  in terms of budget to mid range i would look at corsair's cx series or evga's b or g series.  Sometimes you can acually find corsair's rm series for a decent price and that would probaly be your best bet
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
id get a 650W, as i have similar specs and a 650W :P
anything tier A or up from here is a good choice:
B Tier is also fine if you dont want to spend a lot of money, but i wouldnt cheap out on the one thing that can take your entire system with it
Builds:
I’ve got a 550w psu for my build and it has 2070+2700x. Should be plenty for your’s
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
