Sound from speakers is playing back through my mic for everyone to hear
Solved by Majd,
this is usually happens because of the motherboard or the audio card (chip), changing headsets will not help, it is electrical leak from the headphone to the mic that happens on the motherboard, try using USB audio cards it might fix the problem, there is nothing you can do in the software that can fix the problem.
Featured Topics
monkk ·
Posted in Networking0 -
1
Flashmatrix ·
Posted in Storage Devices8 -
Nixx23 ·
Posted in Storage Devices0
