I am currently planning out my first build. I know its very overkill for my first computer, but other than that is there any recommended changes? I originally planned on getting a 2070 or 2080 but I was scared away by all the reports of them failing.
https://pcpartpicker.com/list/QDs3TB
EDIT: After following the advice of this thread and revising the list here are the results https://pcpartpicker.com/user/KozyKami/saved/7ZYP3C
Thank you to everyone who contributed to this thread. With the help that was provided, I ended up with a very similar performance PC. Even after upgrading the monitors the revised rig is still $500-600 cheaper
Edited by KozyKami
Update
https://linustechtips.com/topic/1052821-my-first-build/
 can't say too much without knowing its uses
at this point it's better to deal with the risk and RMA if needed. The prices of older Nvidia cards raised to unreasonable levels if you buy new.
Desktop benching:
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463861
Motherboard is too expensive, and what are you going to do  with 2x tubes of thermal paste on top of what's pre-applied on the cooler?  It doesn't work as lube, trust me,
2080Ti is way too much for 1080p gaming, even 144Hz.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463868
Looks like I'm SOL until a hyperlink is added
Copy/paste PCpp links give me such trouble on mobile.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463876
Cuz you're a good guy, I'll help...
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463885
why the heck do you need 32gb of RAM? You also don't need 750w of power.
I might be behind on tech news but the only RTX cards that had lots of people talking about them failing was the 2080 Ti
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463890
What's with the double thermal paste? Unless you gotta stock up I guess.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463895
makes me think of my friend who said "yeah I put 9 grains of rice on my fx 6300" and now theres thermal paste in the socket and on the pins and the PC wont POST.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463898
I kinda got overexcited when I first started the list. Now that I think about it I already have 16gb of trident z RGB in my current rig (SI). So i could pay half the price for the same result. Also what kind of wattage would you recommend.
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463907
650 is fine, and provides a little extra power just in case.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463919
I planned on just having some around in the case I ever need it in the event I screw something up.
A single tube is a good handful of applications, getting two will last you a super long time. I've got yet to deplete my first tube of MX-4
Primary PC:
PSU tier list
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463928
Yeah, I added those at the beginning of my quest before my research, now I realize how little you actually use. I guess I just never revisited it.
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463940
Also, with a 2080Ti you need to be at 1440p.  Ultrawide if you want to go that route as well.
Your whole build kind of needs a redo.  $3600 be much better spent, if not under $3000.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463951
At least throw in a nice 360mm AIO when spending this money. Will benefit the OC on the 8700k.
you could also go with a Z370 board to save some bucks
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12463966
I originally planned on using an AIO but saw that the ll120 doesn't have very good static pressure. I'm kind of in love with the look of the fan and want my case fans to match so I'm not sure. Would there be a benefit of throwing some static pressure fans on the back out of sight in combination with the ll120s?
https://linustechtips.com/topic/1052821-my-first-build/#findComment-12464003
