Hi beautiful people!
I'm running now an MSI laptop with an i7 and a 970m slightly overclocked but I decided it's time to grow up and make my own path!
I live in Germany my budget is around 2500 euros and i have peripherals.
I only need it for gaming 1080p 144hz and i would like to get as much horsepowers as possible out or my bucks!
I can't really make up my mind if I need a 2080ti and go cheaper on other things or a 2080 would be enough. From what I read for 144hz gaming I would get the most of an 9900 but it comes with a cost.
I am probably gonna order the components next week so any help is welcome!
Sorry for my English and I wish you all a nice Sunday!
https://linustechtips.com/topic/1052439-first-build/
€ 2500 is a big budget, so I just went crazy on this theoretical build. You can swap out the AIO cooler for normal fan cooling if you want I guess.
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  (€517.99 @ Amazon Deutschland)
CPU Cooler: Corsair - H100i v2 70.69 CFM Liquid CPU Cooler  (€147.16 @ Amazon Deutschland)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  (€179.00 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory  (€212.90 @ Amazon Deutschland)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  (€82.90 @ Amazon Deutschland)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (€44.90 @ Caseking)
Video Card: EVGA - GeForce RTX 2080 Ti 11 GB Black Video Card  (€1099.00 @ Alza)
Case: Phanteks - Enthoo Pro ATX Full Tower Case  (€99.90 @ Amazon Deutschland)
Power Supply: Corsair - HX Platinum 750 W 80+ Platinum Certified Fully-Modular ATX Power Supply  (€109.90 @ Amazon Deutschland)
Case Fan: Noctua - NF-R8 redux-1800 PWM 31.37 CFM 80mm Fan  (€11.89 @ Aquatuning)
Total: €2517.43
Generated by PCPartPicker 2019-04-07 13:57 CEST+0200
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1052439-first-build/#findComment-12460750
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  (€417.89 @ Mindfactory)
CPU Cooler: RAIJINTEK - TISIS 70.2 CFM Sleeve Bearing CPU Cooler  (€66.90 @ Caseking)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  (€186.90 @ Amazon Deutschland)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  (€83.90 @ Amazon Deutschland)
Storage: Crucial - P1 500 GB M.2-2280 Solid State Drive  (€71.90 @ Amazon Deutschland)
Storage: Toshiba - P300 2 TB 3.5" 7200RPM Internal Hard Drive  (€61.90 @ Caseking)
Video Card: ASRock - Radeon VII 16 GB Phantom Gaming X Video Card  (€687.99 @ Mindfactory)
Case: Corsair - Carbide Series 275R (Black w/Tempered Glass) ATX Mid Tower Case  (€79.85 @ Amazon Deutschland)
Power Supply: BitFenix - Whisper M 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  (€104.90 @ Caseking)
Monitor: BenQ - EX3501R 35.0" 3440x1440 100 Hz Monitor  (€599.00 @ Amazon Deutschland)
Total: €2361.13
Generated by PCPartPicker 2019-04-07 14:41 CEST+0200
spending 2500 euros for a 1080p 144hz would be complete overkill, so i added in a 1440p 100hz ultrawide monitor in.
https://linustechtips.com/topic/1052439-first-build/#findComment-12460816
Total: €2517.43
A 9900K on that board ? Good luck with that.
https://linustechtips.com/topic/1052439-first-build/#findComment-12460831
Similar to Herman's spec but with a different res monitor. I agree that spending this much should warrant a better monitor than a 1080p/144Hz.
Monitor is just a placeholder as there are quite a few choices for 1440p/144Hz+. The new Gigabyte Aorus Freesync screen is another option but not sure if it is still pre-order.
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  (€72.44 @ Amazon Deutschland)
Motherboard: Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard  (€199.00 @ Amazon Deutschland)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (€91.90 @ Amazon Deutschland)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  (€68.90 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  (€69.90 @ Caseking)
Video Card: PowerColor - Radeon VII 16 GB Video Card  (€630.34 @ Amazon Deutschland)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  (€84.90 @ Amazon Deutschland)
Power Supply: Corsair - RMx (2018) 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  (€112.90 @ Amazon Deutschland)
Monitor: Asus - MG279Q 27.0" 2560x1440 144 Hz Monitor  (€519.00 @ Alternate)
Total: €2267.17
Generated by PCPartPicker 2019-04-07 15:00 CEST+0200
https://linustechtips.com/topic/1052439-first-build/#findComment-12460858
I mean, you all are probably right about the monitor, but I bought it a couple months ago and I think I will keep it for a while before upgrading! Thanks a lot for all the suggestions!
I think I may be more inclined to go with a rtx rather than a Radeon But I will inform myself about pros and cons of both before making my decision!
https://linustechtips.com/topic/1052439-first-build/#findComment-12460922
btw, PCPP pricing screwup(as usual). cheapest R7 is 688 euros for the asrock model.
https://linustechtips.com/topic/1052439-first-build/#findComment-12460959
you can keep it and use it along with a new monitor, the radeon 7 is slightly cheaper but performs a slight bit worse.
https://linustechtips.com/topic/1052439-first-build/#findComment-12460962
Atm I am not really interested in getting a new monitor, and this year I would be more interested in just getting a beast to be able to let me game 1080p high fps for several years, I went over my budget but could be fine on this build, I am going to OC it as soon as it gets on my desk. Here is what looks like a good plan to me, what would you change?
https://linustechtips.com/topic/1052439-first-build/#findComment-12465426
you're really just wasting money at this point, so many levels of overkill for just a 1080p 144hz rig. spend the money on a better monitor instead.
https://linustechtips.com/topic/1052439-first-build/#findComment-12465428
I hear you on the monitor thing, and it's something I will definitely do. I will probably be getting one in the future, my first aim is now to have a build that lasts as long as it can, and I am into liquid cooling thus why the aio and the Hybrid card. I would love a custom one but I don't think I can make one without experience even if YouTube can help a lot.
https://linustechtips.com/topic/1052439-first-build/#findComment-12465576
If you can wait a bit, zen 2 will have 16 core CPUs compared to 8 on coffeelake, makes for a better upgrade path in the future. If you're sticking to intel the maximus hero is overpriced so stick to the gigabyte aorus boards. You don't need a 970 evo, nvme doesn't make anything futureproof. Get a regular atx case instead of a test bench.
https://linustechtips.com/topic/1052439-first-build/#findComment-12465683
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  (€419.90 @ Alza)
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  (€140.34 @ Amazon Deutschland)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  (€188.99 @ Amazon Deutschland)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  (€79.99 @ Amazon Deutschland)
Storage: Samsung - 860 QVO 1 TB 2.5" Solid State Drive  (€114.90 @ Amazon Deutschland)
Video Card: MSI - GeForce RTX 2080 Ti 11 GB SEA HAWK X Video Card  (€1179.65 @ Amazon Deutschland)
Monitor: ViewSonic - VX3258-2KC-MHD 31.5" 2560x1440 144 Hz Monitor  (€329.99 @ Amazon Deutschland)
Total: €2643.56
Generated by PCPartPicker 2019-04-09 12:38 CEST+0200
https://linustechtips.com/topic/1052439-first-build/#findComment-12465694
Total: €2643.56
I could wait, but since there is always something new to wait for I am not sure I want to, I would just starting postponing endlessly! This build actually looks very very good! Thanks a lot for all the help you gave me and sorry if I went on your nerves
https://linustechtips.com/topic/1052439-first-build/#findComment-12465773
