Your i5 is 4core 4 thread right?
Then they would both work fine, i would go for the 580, because it is faster and has more vram, but if the 1060 is significantly cheaper then it is also a decent option.
But what is your power supply?
Does it have the pcie power cables?
I only see your reply if you @ me.
https://linustechtips.com/topic/1052410-help-me-out/#findComment-12460489
10 minutes ago, Ritam said:
Thanks bro. In india, gtx 1060 is  195$
                                     Rx 580 is 210$
Then i would go for the rx 580 or 570.
8 minutes ago, Ritam said:
Yes. 2 games
 Even better.
https://linustechtips.com/topic/1052410-help-me-out/#findComment-12460510
