Processor : Ryzen 7 1700
Mobo : Asus Strix B-450 F "GAMING"
Ram : 32gb RGB Geil 3000mhz
So I used my same processor and ram on Gigabyte Gaming K7 and was able to hit 3.95 on all cores with 3200mhz ram
i got a new asus B-450-F "GAMING" board and now the same RAM will only clock to 3000mhz which is fine and same CPU is at 3.95
My cinebench score on my old system was in the 1700's so like 1730's ish
its at low 1600's on my new system ? with the same CPU and same RAM
Task manager is also telling me the Cpu is running .4 mhz off my max, i dunno if that is normal...
the overclock is stable though, but score is really low ? any ideas?
https://linustechtips.com/topic/1052291-low-cinebench-after-overclock/
Did you make sure there's no background tasks running?
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
because the memory timings are likely worse. No idea why you're downgrading the board like that
Desktop benching:
i bought it on new egg as open box and there was only a 3 month warranty and it shorted out.. I set it on the "xpm" Amd version on my board, so the timings should be set to the exact ram... nothing more then normal running in the background ... its just weird that i was able to get 1740's before and now 1600's
any help?? any settings i can change ? that  might help it run faster ?
