HDD Docking station: would it work with a 19-pin to USB3.0 converter?
54 minutes ago, Core512 said:I see. Is there any way to make this device work with a laptop?
Not in a way that makes any kind of sense.
One of the key components you'll need to make this work is a USB to SATA bridge cable of some kind. But if you buy one of those you'd still have to split the power off somehow and splice it into that molex power socket (so you'd likely need to buy a molex cable as well and then cut them both apart to rewire them). It would be 100 times easier to just plug the drive directly into the USB to SATA bridge cable the way it was meant to be used.
Cables like the one above sell for under $10 and let you plug a 2.5" drive into a USB port (the one above is USB3 which has a single USB plug, they also sell USB2 ones which have 2 USB connectors to get enough power for the drive)
