There are cheaper RX 580 models, and the the Armour isn't so great it's worth paying more for (actually it's a cheaper model).
I don't personally like that case, but it's all personal preference, and with your lower-power parts the cooling isn't gonna be a deal breaker.
Otherwise seems fine. Pretty good.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
Same build, except I added an SSD.
SSDs are 100% necessary for a modern boot drive, imo. Booting off a fast HDD vs a slow SSD is like a 20+ second difference. You can get cheaper SSDs (Kingston 120GB), I just threw in my usual pick.
The rest of the system should be pretty good.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
I'm gonna get the msi rx 580 for really cheap
I believe the ARMOR OC coolers can be hit and miss, so I changed the rx 580 model to a powercolor red devil, which is always a reliable model. I also saved some money on the motherboard (And gpu as well) to make some way for an ssd and a better psu:
imo, best AMD GPU brand.
*GPU Test Bench*
Yeah, but the OP's mobo has much better power delivery. it was a good choice for overlocking and potential upgrades.
I would save money on the GPU, case before compromising on the board.
It's cheaper and easier to get a long-term motherboard and wait a bit for more storage than get a cheap board and have to rebuild and waste a component when they decide to overclock more (once they get a better cooler) and/or upgrade the CPU
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.89 @ OutletPC)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($99.97 @ Amazon) VRMs are the same as the tomahawk.
Memory: Team - T-Force Vulcan 16 GB (2 x 8 GB) DDR4-3200 Memory  ($79.99 @ Newegg)
Storage: HP - EX900 250 GB M.2-2280 Solid State Drive  ($44.89 @ OutletPC)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($38.69 @ Amazon)
Video Card: MSI - Radeon RX 580 8 GB ARMOR OC Video Card  ($189.89 @ OutletPC)
Case: Cooler Master - MasterBox Pro 5 RGB ATX Mid Tower Case  ($70.98 @ Newegg)
Power Supply: Cooler Master - MWE Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ B&H)
Total: $744.29
Generated by PCPartPicker 2019-04-05 23:03 EDT-0400
