Hello,
I need urgent help. My friend told me to transfer his pictures from mobile phone CAT S41 (android) to his SD card. I connected mobile phone to PC and in internal card (DCIM->Camera) I marked all files and used option cut. Then I put option paste on his sd card. After few seconds of copying, copying just stopped (some windows sound was heard) and when I looked is storoge space on internal card there were no pictures. In SD card there is just small ammount of pictures copied. Seems like all pictures was deleted!!!!??? I tryed with program Dr. Fone but when he analyse device, progress bar is very slow and mobile phone is restarting every 2 minutes. What else could I tryed to restore this data?
https://linustechtips.com/topic/1051860-error-during-copying-urgent-help/
recycle bin?  anyway, I know it doesn't help now, but this is why it's always preferable IMO to use copy-paste, then only delete originals on the device after checking they all copied correctly.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Nothing in recyle bin, even if it was I think that all that GB of pictures and videos couldn`t fit in recycle bin. I think I read before that CUT should be safe becausee windows should act smart with CUT, they should delete file on original destination only after is transfered to new.
1 minute ago, Mbowen said:
If you haven't panicked yet and started copy/pasting again. Hit "ctrl + z" and you may be able to restore the files to the cell. Also, you could try pasting back to the phone. Depends if your clipboard has been re-written yet.
No I alreday use copy option again.
Any program to try?
With Dr. fone in past I managed to restore all pictures when on my friend phone windwos update deletes some things but this time it just anaylze device.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
