Ubiquiti Edgerouter X and Quanta LB4M
21rkosta
I have an LB4M switch that I am trying to use with my ubiquiti edgerouter X. So far I have gained console access through a serial cable. Then I turned on all ports and plugged in both a port on the main switch and the management port to the router. I got the management port to grab an IP via DHCP and that allowed me to get into webUI. I still cannot figure out how to setup this switch in just a normal switch way. The ports on the switch flash orange lights when I plug into it. I have tried enabling DHCP on the switch portion of the switch and it will not grab an IP. If anyone knows what I am doing wrong or any potential fixes I would love some help
Thanks
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
