So today i booted up my PC and noticed my pump was making an odd grinding sound.... So i cycled the power switch on/off a few times and the sound has lessened but not totally gone. Is it possible my pump is already going out? My liquid cooling setup is only maybe 6 months old. I bought the kit initially as a start up thing and had planned on upgrading to a full arcyllic pump/red combo in the future but atm i am waiting on 7970 prices to drop back down so i can get a second one... Should i just keep cycling the system on/off or see if it fixes itself? Or do i need a new res?
LINK: http://www.thinkcomputers.org/xspc-raystorm-750-rs240-watercooling-kit-review/
My rig: Case: Corsair 760T CPU: Intel 4690k MOBO: MSI Z79 Gaming 5 RaM: 16gb HyperX SSD: 256gb Samsung pro HDD: 1tb Toshiba PSU: Thermaltake smart 750 GPU: 1x GTX 1080 Founders edition
https://linustechtips.com/topic/105165-pump-grind/
These pumps are know to "grind". You will need to RMA it. If you get as new pump get a Laing pump as they have an MTBF of 5 years.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/105165-pump-grind/#findComment-1406003
Wouldnt i have to take apart my entire setup to RMA since i got it as a kit?
https://linustechtips.com/topic/105165-pump-grind/#findComment-1406067
Email XSPC and ask.
https://linustechtips.com/topic/105165-pump-grind/#findComment-1406080
