Running Open Case / Side Panel Safe For GPU Temps?
My GPU is Verticality mounted within the case but this means it’s right up to the glass side panel with only a very small space in between.
This means the GPU fans are blowing straight at the glass.
Is it safe to leave the Glass Side Panel off completely?
I would ofc use some compressed air to get rid of any dust build up but this should then immensely help the GPU breathe?
3 minutes ago, Knight77 said:
My GPU is Verticality mounted within the case but this means it’s right up to the glass side panel worth only a very small space in between.
Yes, it would be like an open test bench then.  Better than starving them for air.  Btw, the fans are sucking air from, not blowing air at the glass, they blow air onto the heatsink on the card.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Ah ok, so they blow in, then it shouldn’t really impact the the GPU?
Or would this still be an issue?
there is a large fan directly above the GPU and also 2 huge ones at the front.
Just looking for best suggestions on what to do.
Just how much room is there between the GPU and the glass panel?
If it's too close, the fans can't pull enough air from around them.  You want around an inch or so, give or take.  The other fans are nice to create movement as well.
OnePlus Ecosystem:
3D Printing:
Probably between 1.5-2.5cm
If the GPU was struggling, I’d hear it crank up the fans right? - and this would be extra noticeable if it was doing it early on?
When in gaming they hardly ever speed up to max - so this would be a noticeable difference if there wasn’t enough air getting in now that is Vertical?
When in gaming they hardly ever speed up to max - so this would be a noticeable difference if there wasn’t enough air getting in?
Yeah, just monitor temps and see where they are at idle, gaming, stress test, etc.
You may have enough room to only incur a couple degrees of increased temperature, should be fine.
OnePlus Ecosystem:
3D Printing:
Which software is the best to track temps and clock speeds?
Is there a certain temp the GPU shouldn’t be going over?
I use HWINFO64 and MSI Afteburner.  I like to stay in the low 70's during gaming, peaking in the high 70's.  You may hit 80 or so during gaming, not really an issue.
HWINFO64 for all if its sensors and MSI Afterburner for setting fans curves and power usage and temp max.
OnePlus Ecosystem:
3D Printing:
Ok thanks,
So MSI Afterburner can record temps in the background while playing and so you know over a 2 hour period what the temps were?
I have downloaded both to be sure ?
