Best GPU for 500-600 CAD?
IBojo
I'm currently ordering parts and have most of what I need. I still need the GPU and since there are so many on the market I was wondering what you guys think is the best option for around 500-600 CAD
I'm making an AMD build with the 2700x with the ASUS X470 MOBO
I would say go with a 2060 or if you want to spend less go with a 1660Ti.  What is your preference ? Evga or MSI or Gigaybte or ASUS ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
@Slottr Yes for gaming. I was hoping for 1440p and whichever refresh rate makes sense for that price range. If I can get significant improvement in the GPU for an extra $100 (meaning 700 CAD total) I may consider it.
@Turtle Rig Don't have a preference as this is my first build and am un-familiar with the brands. My case is going to be black and white if that makes any difference.
Thanks guys :)
Thanks guys :)
Go with this MSI 2060  and don't look back.  Do you care about RGB lighting ?
2070 will do well at 1440p, will be okay to get a higher refresh rate display as well. I'd shoot for about 100-120hz.
https://ca.pcpartpicker.com/product/mYYLrH/evga-geforce-rtx-2070-8gb-black-video-card-08g-p4-1071-kr
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
My bad Stottr ;  But a 2070 would be out of his budget no ?
Read their previous reply.
  • 1 year later...
my geforce rtx 2060 super dual evo v2 gpu fans stopped working. it was working yesterday and the gpu tem was 26C and when I used it today I lopoked at the gpu temps it went up to 47C and when I checked it the fans are not spinning
Then you should make a thread about it, not hijack a dead thread to mention your problem.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
